Showing Articles written by Nathen Blas
SOLIDWORKS PDM Sep 09, 2026
Managing non-CAD files like Engineering Change Orders (ECOs), instruction PDFs, or component data sheets alongside your models can be tricky. In SOLIDWORKS PDM, the Paste as Reference feature lets you link external documents directly to a part, assembly, or drawing, keeping your project context complete and easy to navigate.
SOLIDWORKS Electrical Dec 17, 2025
Tells are little signals that give hints as to the nature of various situations. Much like a poker player reading their opponent, or a performer "reading" a person's mind. Tells let these people know more information than is readily given. SOLIDWORKS Electrical also has little tells to share more information than is plainly stated.
SOLIDWORKS Electrical Oct 24, 2025
When working in SOLIDWORKS Electrical, setting up a Project Template is an essential part of the process, and setting it up effectively will save you a significant amount of time later when creating Electrical Projects. A tool that is often overlooked when setting up templates is the Drawing Styles Configuration.
SOLIDWORKS Electrical Oct 07, 2025
When working in SOLIDWORKS Electrical, there may be a time when items such as manufacturer parts, cable parts, symbols, and title blocks need to be updated or replaced. This can be quite the tedious process if there is a large number of that item in your project. Luckily, SOLIDWORKS has a solution for this: the Replace Data command.
SOLIDWORKS CAD Aug 06, 2025
Everyone who has used SOLIDWORKS has at one time or another experienced a crash; whether that be a one time instance or a steady occurrence. In this guide, I will discuss some steps for how to troubleshoot SOLIDWORKS crashes, especially if this is a steady occurrence. Note: This process will not work well with random occurrences as it requires some repeatability.
SOLIDWORKS Electrical Jul 22, 2025
When working in SOLIDWORKS Electrical, you will often need Programmable Logic Control (PLC) for automation. This guide explains the process for adding PLC Drawing configurations to Electrical projects.
SOLIDWORKS Electrical Jul 14, 2025
When working in SOLIDWORKS Electrical, placing symbols and defining part info is common practice. However, there are times when a symbol always has the same info, and having to re-enter it every time the symbol is placed is time-consuming and redundant. This article explains how to save this data to a symbol for easy access and placement.
SOLIDWORKS Electrical Jul 09, 2025
When working in SOLIDWORKS Electrical, changing user data fields to more relevant property names can be a helpful step for companies when reporting. Doing so helps to eliminate the need for a "cheat sheet" to keep track of which user data field corresponds to which property. Each component classification gets its own user data fields and can be modified as needed. This guide will go over the steps to do so.
SOLIDWORKS Electrical May 29, 2025
In SOLIDWORKS Electrical, certain items are shared across the program, while others, like Wire Styles, are specific to the project they were made in. This can cause extra work if you frequently use the same wire styles across some or all of your projects. However, there is a way around this. By creating your commonly used wire styles and saving them in a custom template, you can avoid recreating styles and instead have them readily available for any future projects. In this guide, we go over the steps to create the wire styles and the custom template.
