Replace a SOLIDWORKS Sketch Entity Without Rebuild Errors
 Article by Zach Brown on Jul 06, 2026
In SOLIDWORKS, when you delete a feature’s sketch entity and replace it with another, it can have negative downstream effects in your model. The reason is that SOLIDWORKS generates a new face in the feature that used the previous sketch entity. Features that referenced the previous face or sketch entity will have rebuild errors. To resolve this, SOLIDWORKS has a sketch tool called Replace Entity.
Where is Replace Entity Located?
The Replace Entity tool can be found in Tools > Sketch Tools > Replace Entity (an active sketch is required).
Where Is the Replace Entity Tool Located in SOLIDWORKS?
How to Use Replace Sketch Entity
Here, we have a model with a curved top face created from a 3-point arc. There are also child features of the parent’s curved face. We want to replace the 3-point arc with a spline that has a slightly different curvature.
SOLIDWORKS Model with a Curved Top Face
Deleting the 3-point arc and replacing it with a spline will cause errors in the child features.
SOLIDWORKS Child Features Error
Instead of deleting the 3-point arc (or making it construction geometry), we will edit the sketch, add the spline as construction geometry, then use Replace Entity to swap one for the other.
In the Replace Entity PropertyManager, select the arc for “Replace this entity”, then select the spline for “With this one”. We can choose to make the arc construction geometry to leave it in place, or select the radial button to delete the arc. We also have a radial button to make the spline contour geometry.
SOLIDWORKS Replace Entity Tool Options
After making the proper selections, click the green check mark and close the sketch. The result is a model with no rebuild errors.
It is worth noting that this works best with subtle geometry changes. There may still be errors if the replaced entity is completely different from the original. Also, this could affect mates in an assembly where a tangent mate was applied when it was an arc. Tangent mates cannot be applied to faces made by splines.
How to Replace a SOLIDWORKS Sketch Entity Without Rebuild Errors
Want to learn more about SOLIDWORKS? Check out additional tutorials and tips below. Additionally, join the GoEngineer Community, where you can create forum posts, enter design contests, and answer questions from other SOLIDWORKS users.
SOLIDWORKS CAD Cheat Sheet
Introduction to SOLIDWORKS Mates: Standard, Advanced, & Mechanical
SOLIDWORKS Worm Gear Mate Quick Tip
Missing SOLIDWORKS Bend Lines in Flat Pattern DXF
Changing Component Colors in SOLIDWORKS Drawings
Modeling Conveyor Belts with Cleats in SOLIDWORKS
View All SOLIDWORKS Tips
About Zach Brown
View all posts by Zach Brown
