The installation of SOLIDWORKS can fail to complete for several different reasons including insufficient user permissions and actively running antivirus/firewall applications. One installation error that can be particularly problematic to troubleshoot is error 1402. This guide will cover the symptoms tied to the SOLIDWORKS installation error 1402 and the workflow to resolve it.
Suggested Article >> Fix SOLIDWORKS Resources Running Low
Error 1402 usually indicates a lack of user permissions to read/write registry keys during the installation.
Suggested Article >> Creating a SOLIDWORKS Local Dump File
The resolution to installation error 1402 requires modifying a key in the Windows registry. Care needs to be taken when working in the Windows registry. It is recommended to back up the Windows registry before making any changes.
To resolve the problem, the owner of the Components key and all sub-keys need to be changed to a user with administrative rights. The owner of the Components key is set to System by default. Corruption in the Windows registry can cause problems with the installer opening and modifying sub-keys under Components using the System account.
I hope you found this article helpful. Check out more SOLIDWORKS tutorials below.
NVIDIA RTX Series: GPUs for SOLIDWORKS and Visualize
