Adding and Removing Search Paths in SOLIDWORKS
 Article by Matthew Kusz on Feb 18, 2026
When searching for documents within SOLIDWORKS, the software references a list of search paths, located in System Options > File Locations > Search Path. In addition to the defaults, you can easily add additional search paths. Unfortunately, it's not always so easy to remove them. This article explains how to add and remove stubborn search paths in SOLIDWORKS.
Add a Search Path
To add a new search path, go to SOLIDWORKS Options > System Options > File Locations > Search Paths.
Add a Search Path in SOLIDWORKS
Click Add, browse to a folder, and click Select Folder (the same process as adding any file location).
After you click OK in System Options, User Account Control might display a message like this:
SOLIDWORKS Search Path User Account Control Message
This is SOLIDWORKS helpfully adding this new search path to Windows' indexing list. Click Yes.
Remove a Search Path
If you need to remove a file location from System Options, the process is similar and straightforward...except for Search Paths. If you try to delete a search path, it disappears from the list as you'd expect.
Delete a Search Path in SOLIDWORKS System Options
But if you open System Options again later, you may find that it's still there.
SOLIDWORKS System Options, File Locations, Search Paths
This is due to SOLIDWORKS not automatically removing that path from the Windows indexing list.
Windows Indexing Options
To remove a stubborn search path from SOLIDWORKS, you'll need to make a change to your Windows indexing options. Find this in the Windows Control Panel by searching in the Start menu.
Search Windows Indexing Options from the Start Menu
Windows Indexing Locations
Once open, click the Modify button and uncheck the folder you wish to remove.
Modify SOLIDWORKS Search Path via Windows Indexing Options
Modify Windows Indexing Options
After clicking OK, you'll see the folder has been removed from the indexing options.
Folder Removed from Windows Indexing Options
If you return to System Options > File Locations in SOLIDWORKS, you'll notice the folder has been removed from the Search Paths list.
How to Remove a Search Path from SOLIDWORKS System Options
I hope you found these steps helpful. Check out more tutorials below. Additionally, check out the GoEngineer Community, where you can create forum posts, enter design contests, and answer questions from other SOLIDWORKS users.
SOLIDWORKS CAD Cheat Sheet
Learn More
Ballooning Subassemblies in a SOLIDWORKS Drawing
Why Your SOLIDWORKS Drawing Balloons Have Question Marks (?) or Asterisks (*)
VIEW ALL SOLIDWORKS TUTORIALS
About Matthew Kusz
View all posts by Matthew Kusz
