Revision control is a key reason companies adopt data management systems like PDM/PLM. The 3DEXPERIENCE platform makes it easy (sometimes too easy) to access older file revisions. A common question is, "How can I view only the latest revision without the clutter?" In this blog, we’ll explore three ways to filter search results and focus on the most current version.
Here is a rundown of some of the SOLIDWORKS 2026 enhancements in the area of collaboration and the 3DEXPERIENCE platform. Working with large assemblies can be challenging. Oftentimes, the only way to have the total context of a design is to open all the parts you don’t need to work on, just the parts you do need.
Derived Outputs on the 3DEXPERIENCE platform are PDFs, DXFs, STEP files, etc., that are manually or automatically created from your CAD files for use downstream. This article explains how to “package” these outputs and export them from the platform to send to someone outside of the company.
3DEXPERIENCE users often ask, “How can I release an assembly and all of its parts, sub-assemblies, and related files (especially drawings)?” Releasing all the sub-assemblies and parts (either manually or from a Change Action) is fairly easy, but also including all of the drawings is a bit more challenging. This blog explains an easy way to accomplish this.
In the 3DEXPERIENCE platform, Thumbnail is a useful column that can be added to the Bookmark Editor app. Since the July 2025 platform update, adding this column, as well as many others, to the Bookmark Editor has changed slightly. So, let’s look at how to add these special columns.
Let’s look at a major time-saver - using the Engineering Release app in the 3DEXPERIENCE platform to change/add properties (metadata) to parts and assemblies that have already been saved to the platform. The Engineering Release app is included with the Product Release Engineer role. This is a role that can be added to your platform for certain users who need it. This role is considered the “BOM Release/Management” role, and its main purpose is to manage product definition from the early stages all the way to final validation.
In 2024, 3D Sculptor (xShape) in 3DEXPERIENCE introduced a feature that allows users to create their own SubD primitives by Extrude or Revolve. While this may seem straightforward, this functionality can be applied in various scenarios that we will explore further.
Many new administrators and users of the 3DEXPERIENCE platform often have questions about Collaborative Spaces—specifically, their visibility settings and member permissions. While this can be confusing at first, the information and tables below will help you implement Collaborative Spaces effectively.
A common question I hear from 3DEXPERIENCE users is, “How can I see if a part or an assembly has any associated drawings?” Turns out there are many ways to get this information. In this blog, I’ll start with some simple methods and then move on to some that take a little more setup but are worth the effort.
