Did you know that you can change the language in SOLIDWORKS without needing to change the language of your system? It's possible and relatively simple.
The easiest way to change the language in an existing SOLIDWORKS installation is by tricking SOLIDWORKS into thinking the new language is English. There must be a full installation file set for the wanted language. Follow the instructions below to modify your SOLIDWORKS installation to install the full-file set for the desired language.
To install SOLIDWORKS with the specific language right off the bat, select the desired language(s) in the “Product Selection” page of the installation, then follow steps 6 - 10 as discussed above.
I hope you found this article helpful. Learn more about SOLIDWORKS in the tips and tricks below.
BOM Compare - SOLIDWORKS Utilities
SOLIDWORKS Toolbox Default Search Location Option
Link Sketch Text to File Properties in SOLIDWORKS
About Tashayla Openshaw
