SOLIDWORKS PDM Update References Tool Use and Options
 Article by Sean Mark on Mar 10, 2026
Managing file references in SOLIDWORKS PDM is often a seamless, automatic process. The vault does most of the work for you. When you come across files with incorrect or broken references, however, PDM provides a streamlined method to fix them.
The most common scenario we encounter jumbled references is when files are being brought into the vault. Whether it’s one assembly and its parts, or an entire directory, if files are imported in the wrong order, references can end up all over the place.
This leaves a mess for your users to sort through when searching for all the files related to a project. It can also result in multiple errors in PDM and SOLIDWORKS, such as check-in warnings, suppressed parts, and broken mates, making it difficult to work with the files.
The Update References tool is meant to alleviate these issues in a much quicker and more automated fashion than manually repairing each path one by one in your SOLIDWORKS FeatureManager Design Tree.
The example used here to showcase the Update References tool is based on a common scenario where just the assembly file is added to the vault from a location outside the vault and checked in, while its referenced part file was later added to a different subfolder.
Example of Error During Check-In:
SOLIDWORKS PDM Check-In Error
We’ll Cover the Following:
  1. Accessing the Update References Tool
  2. Replace File
  3. Add Files to Vault
  4. Show Properties
Accessing the SOLIDWORKS PDM Update References Tool
To access the Update References Tool, left-click and highlight the assembly or drawing file in question that contains broken references.
While the file is highlighted, click Tools and then click Update References…
Note: Users will need to check out the rights to the files they want to update the references for. If the file isn’t already checked out to that user, the tool will check out the file for them.
SOLIDWORKS PDM Update References Tool Location
Once open, the tool will show the selected file, all referenced files, their current locations, and any relevant warnings.
The Update References tool has a few different options to choose from based on what you’re trying to do.
SOLIDWORKS PDM Update References Tool Options
Replace File
If you know the individual reference file that needs to be corrected and want to take a more detailed approach, use the Replace File option.
Click and highlight the reference file in question (see Outside SOLIDWORKS PDM warning under the Warnings column).
SOLIDWORKS PDM Update References Replace File
This should make the Replace File button available to click: SOLIDWORKS PDM Replace File Icon
Once you click Replace File, a new window will open, which allows you to select the file you’d like to replace this reference with.
Browse to the location within the vault and select the file in question. Then click Open.
SOLIDWORKS PDM Replace File Vault Location
When successful, you’ll see the following prompt. Click OK.
SOLIDWORKS PDM Update References Message The File Was Successfully Replaced
Verify that the file shows OK (Modified) under the Warnings column and that the Found In column shows the new path for the part file within the vault. Click Update.
Update References Tool Use in SOLIDWORKS PDM
You should then see the following prompt, stating that it was successful.
References Were Successfully Updated Message in SOLIDWORKS PDM
Add Files to Vault
In some situations, the reference files were added to the vault folder but weren’t actually added to the vault. This makes them appear as local files instead. When this happens, use the Add Files to Vault option to add them to the vault and update the references at the same time.
Click the Add Files to Vault button: Add Files to Vault Icon in SOLIDWORKS PDM
Select the root vault folder and click Next.
Select the Root Vault Folder in SOLIDWORKS PDM
Verify that the files that were local are shown in the list to be added, and then click Finish.
Add Files to Vault in SOLIDWORK PDM
Verify that they are listed, and then click Update.
Show Properties
The Show Properties option is more for informational purposes. It displays the properties window of the file selected, where you can verify if the file is set to read-only, view the file data card, or verify who has permission to see the file.
General tab
SOLIDWORKS Show Properties General Tab
File Data Card tab
SOLIDWORKS PDM File Data Card Tab
File Permissions tab
SOLIDWORKS PDM Properties File Permissions Tab
Summary
The Update References tool allows you to correct broken references of assemblies and drawings while giving you control over what is being updated, and getting it done in a much easier way compared to your standard slog through suppressed components.
If you have a large dataset you need to migrate into your PDM – whether it’s a legacy OneDrive or combining two vaults into one – GoEngineer offers Migration Services to help make this process seamless and worry-free.
If you’d like to see how validating the process on your own might go, we recommend checking out the Data Migration Validation guide for more tips.
If these steps don’t work for you or if you have any questions on this process, you can reach out to our Technical Support team for more help if GoEngineer is your SOLIDWORKS partner.
Improve Windows 11 File Explorer Performance with SOLIDWORKS PDM
Avoid Upgrade Surprises: SOLIDWORKS Electrical Connections with PDM
Search for Hidden Variables in SOLIDWORKS PDM
Removing or Deleting a Local Vault View in SOLIDWORKS PDM
SOLIDWORKS PDM – Create Local Host File Workaround as Temporary Solution
VIEW ALL PDM ARTICLES
About Sean Mark
Sean is a Sr. SOLIDWORKS Technical Support Engineer at GoEngineer.
View all posts by Sean Mark
