GoEngineer Blog
#1 Technical Resource Worldwide – Right at Your Fingertips.
Search or Browse SOLIDWORKS & 3D Printing Product Developments, Announcements, How-To Guides, and Tutorials
Category
SIGN UP TODAY!
Get our wide array of technical resources delivered right to your inbox. Unsubscribe at any time.
GoEngineer Community
A forum created by engineers, for engineers. Join to access industry experts and connect with the engineering community.
CATIA May 01, 2025
For some, the idea of designing products with an Excel spreadsheet may seem far-fetched. How can a spreadsheet have anything to do with the design process? A spreadsheet contains only rows and columns of data, right? There is no doubt that spreadsheet data will never replace feature-based geometric modeling. However, a spreadsheet can perfectly complement the parameterization of a part model where several configurations are anticipated. In this blog, we will explore the different Dassault Systèmes 3DEXPERIENCE CATIA solutions that use a spreadsheet to simplify the creation and management of a group of similar parts, commonly called a component family.
SOLIDWORKS PDM Apr 29, 2025
In certain instances, it is quicker and easier to make a SOLIDWORKS PDM Local Vault View using a .CVS file, whether that is due to an error with the install, connection with the server, or permissions. If you have an existing Local Vault View and access to the Admin tool you can make the .CVS file from information located in this View. Let's take a look at how to get this information and how to use the .CVS file.
SOLIDWORKS PDM Apr 25, 2025
Like any secure application, there may be times when you need to update your SOLIDWORKS PDM password. Whether you’re a PDM administrator updating credentials for a user, or a user changing your own password, the process can be completed through the SOLIDWORKS PDM Administration Tool. Below, we’ll walk through the steps for both scenarios.
Creating custom coordinate systems in SOLIDWORKS is a fundamental skill used for precise positioning, orientation, downstream analyses, and many others. Typically, defining a coordinate system is straightforward: select a vertex for the origin, then choose model edges or reference geometry to establish the x, y, and z axes in the desired orientation:
3DEXPERIENCE Design Apr 22, 2025
Managing the members in your 3DEXPERIENCE Tenant is a common task. As employees leave and new hires join the company, the Platform Administrator must control users’ access to the 3DEXPERIENCE platform. New members are added, assigned appropriate Roles, and given access to a Collaborative Space. Members who no longer need access are removed. This blog will go through the settings to add, remove, and manage members in 3DEXPERIENCE.
SOLIDWORKS PDM Apr 21, 2025
If you know anything about SOLIDWORKS PDM, you know its two major components are comprised of an archive server and a database server. The database server is powered by Microsoft SQL. Each vault has a database in SQL that houses just about everything you see in a vault that isn’t the actual files themselves. Everything from your data cards and workflows to user information and licensing is stored in SQL. This is invaluable data - and it should be approached with caution if you want to preserve the integrity of your vault infrastructure.
SOLIDWORKS PDM Apr 18, 2025
When cleaning up your SOLIDWORKS PDM vault from unnecessary user accounts, you can utilize the SOLIDWORKS PDM Administration app to delete a single user or multiple user accounts at once.
SOLIDWORKS CAD Apr 17, 2025
The GoEngineer Team has been busy this quarter, attending the top engineering and technology events in the country. From Houston for 3DEXPERIENCE World to RAPID + TCT in Detroit. Let us fill you in on the latest updates and hot topics from the conference center floor.
3D Printing Apr 16, 2025
You asked, Stratasys answered, with four new products! Stratasys hit the ground running at RAPID + TCT 2025 in Detroit, Michigan, with four powerful product releases, each serving as a direct response to user feedback on existing 3D printing limitations.
