SOLIDWORKS 2027 delivers focused improvements across parts, weldments, and sheet metal, plus better ways to work with external and legacy data.
Here’s what changed, where to find it, and when each tool earns its place in your workflow.
| Feature | Area | Arrived in | What it changes |
| Chord width in Constant Size Fillet | Parts | SOLIDWORKS 2027 | No more switching to Face Fillet for a constant-width fillet |
| Enumerated sketch relation groups | Parts | 2026 FD01 | Multi-entity relations are grouped for faster edits and cleanup |
| Point cloud import upgrades | Parts | SOLIDWORKS 2027 | Larger clouds, E57 support, and full color |
| Auto-detect weldable edges | Weldments | SOLIDWORKS 2027 | One click finds every contact edge and builds the weld paths |
| Section modulus in Section Properties | Weldments | 2026 FD02 | Beam stress inputs for any cross section, including custom profiles |
| Legacy sheet metal upgrade | Sheet metal | SOLIDWORKS 2027 | Pre-2009 parts gain modern sheet metal features without a rebuild |
| Stamp across multiple faces | Sheet metal | SOLIDWORKS 2027 | Stamps can span faces, including unfolded bend regions |
| Per-bend radius in Convert to Sheet Metal | Sheet metal | 2026 FD02 | Set the radius of each bend on imported solids |
A chord width fillet holds the straight-line distance between its two tangent edges constant, rather than holding the radius constant. That makes it the right choice when the width of the blend matters more than its curvature, such as a consistent land on faces that meet at changing angles.
Until now, that option lived only in the Face Fillet tool, which meant leaving the fillet type you normally use. In SOLIDWORKS 2027, chord width is available directly in the Constant Size Fillet command, right next to the option to switch between symmetric and asymmetric fillets. Same command, one more way to define it.
Introduced in 2026 FD01, enumerated groups organize sketch relations that are applied across multiple entities. Instead of tracking down the same relation on each entity one at a time, you can select the group and edit or delete it as a set.
For heavily constrained sketches, especially ones you inherit from someone else, that makes design changes faster and lowers the risk of leaving stray relations behind.
If you work from 3D scan data, SOLIDWORKS 2027 brings a significant upgrade to point cloud import:
Import and work with larger point clouds than previous releases could handle, so less time goes into decimating scans before they reach CAD.
Bring in data in E57, the industry-standard format for point cloud exchange, without an extra conversion step.
Point clouds now display in color, which makes it easier to read surfaces, features, and context in the captured scene.
Which license do you need? Point cloud import is part of SOLIDWORKS Premium. SOLIDWORKS Professional and Standard users can’t import a point cloud, but they can view one that has already been imported into a file.
Picking weld edges on a large multibody frame has always been tedious and easy to get wrong. The Weld Bead PropertyManager in SOLIDWORKS 2027 adds a button that does the selection for you:
Open Weld Bead in your multibody part and set a gap tolerance if bodies don’t touch exactly.
SOLIDWORKS identifies and selects every edge where bodies are in contact or fall within your tolerance.
A separate weld path is generated for each pair of bodies it finds, keeping the result organized.
The PropertyManager stays open, so you can check each path and adjust the beads before inserting them.
Released in 2026 FD02, Section Properties now reports the section modulus for any cross section. Standard profiles have published values, but custom and complex weldment profiles usually meant a separate calculation or a spreadsheet.
Bending stress in a beam is the bending moment divided by the section modulus (σ = M / S). With S reported directly in SOLIDWORKS, you can check a custom profile’s stress the moment you have the load case, without leaving the model.
Sheet metal parts created in SOLIDWORKS 2008 or earlier use an older architecture that can’t take advantage of newer sheet metal features. Historically, the only way forward was to remodel them.
The Stamp feature has always been limited to a single planar face. In SOLIDWORKS 2027, a stamp can span multiple faces, including a bend face when the body is unfolded.
The stamp still needs a planar face to work on, so the workflow is to unfold the part, place the stamp across the flat region, then fold it back up. When the part is refolded, the stamped geometry follows the bend exactly as you’d expect, so it reads correctly in both the formed model and the flat pattern.
When you import a non-parametric solid of a sheet metal part, such as a STEP file from a supplier, Convert to Sheet Metal adds SOLIDWORKS sheet metal capabilities to the body. Previously, the command relied on the bend radii found on the imported model.
Since 2026 FD02, you can edit each bend individually and assign the radius you need. That’s useful when the imported geometry doesn’t match your shop’s tooling, or when a few bends need a different radius than the rest.
Every SOLIDWORKS user will find something useful here, but three groups stand to gain the most right away:
Larger, full-color E57 point clouds shorten the path from scan to model in SOLIDWORKS Premium.
Auto-detected weld paths and built-in section modulus cut both modeling time and side calculations.
Upgrading pre-2009 sheet metal and setting per-bend radii on imported parts unlock data that used to need rework.
Taken together, these tools help you model faster, reduce errors, and send higher-quality designs to production with confidence. Want to keep sharpening your skills? Take a look at the CSWPA-Sheet Metal and CSWPA-Weldments certifications.
This post covers parts, weldments, and sheet metal. The full launch event goes further, with GoEngineer experts walking through the release’s standout features, performance gains, and AI capabilities.
SOLIDWORKS 2025 Sheet Metal: What’s New
