GoEngineer Blog
#1 Technical Resource Worldwide – Right at Your Fingertips.
Search or Browse SOLIDWORKS & 3D Printing Product Developments, Announcements, How-To Guides, and Tutorials
Category
SIGN UP TODAY!
Get our wide array of technical resources delivered right to your inbox. Unsubscribe at any time.
GoEngineer Community
A forum created by engineers, for engineers. Join to access industry experts and connect with the engineering community.
SOLIDWORKS PDM Dec 03, 2025
When adding a local vault view to SOLIDWORKS PDM, users may run into a security measure known as Attach Access Permission. Effectively, this is meant to make it harder for users who do not have permission to create a local vault view and gain access to potentially sensitive vault data. This permission becomes more important when users from outside of the organization are invited to interact with files through the vault. When a PDM Archive Server is created, the server is prepopulated with a user and group permissions for Administration and attach access. We’ll discuss the default settings as well as how to change them below.
3DEXPERIENCE Design Dec 02, 2025
This article explains how to add and use non-CAD documents on the 3DEXPERIENCE platform, covering everything from adding files to Collaborative Spaces to converting those files upon release. Let’s get file-ing in 3DEXPERIENCE!
With the SOLIDWORKS Flex feature, you can create some very complex designs - without much effort. It can be used for various applications, including concept development, mechanical design, industrial design, stamping dies, molds, and more. The Flex feature can change either a single body or a multibody part, and includes 4 different flex types: Bending, Twisting, Tapering, and Stretching. Consider the baluster component of the spiral staircase below. We can take a simple square design and, with the aid of the Flex feature, create a more aesthetic look.
3DEXPERIENCE Design Nov 26, 2025
This article outlines how to add 3DEXPERIENCE platform information to a drawing title block, covering everything from property creation to saving the drawing template.
SOLIDWORKS Electrical Nov 25, 2025
When SOLIDWORKS Electrical is first installed, the Manufacturer Parts Library includes a collection of manufacturer parts inside the database. This is intended as a starting set of parts. Not every user will want all of these, and some will want more. Often, there is a need to share manufacturer parts. You may want to have a common set of parts that are used in projects created or modified at other locations. To facilitate this, we can use the archive and unarchive tools in the Manufacturer Parts Library Manager.
SOLIDWORKS Visualize Nov 24, 2025
SOLIDWORKS Visualize supports native GPU acceleration on AMD hardware (RDNA™ 2 and newer) using the 3DS Stellar Fast rendering mode, Visualize’s interactive ray tracing engine based on Stellar RealtimeGI. Previously, if you used SOLIDWORKS Visualize on a computer with AMD GPUs, you had to use the AMD Radeon™ ProRender rendering engine. This change streamlines the user experience and reinforces native AMD hardware support.
3DEXPERIENCE Design Nov 21, 2025
As Fibonacci Day approached this year and I mulled over what to challenge myself to model, I arrived at an interdisciplinary objective: to create a conceptual architectural model inspired by something found in nature - the nautilus seashell. This cross-section of structural design and nature is known as biomimetic architecture, whose formal definition is the practice of designing buildings and structures by imitating processes and forms from nature.
SOLIDWORKS CAD Nov 21, 2025
Network drives are a common solution for engineering teams to collaborate. They can be a convenient solution for organizations attempting to centralize their data. Operating from a network drive, however, is about the worst way to access SOLIDWORKS data, and teams using network drives are leaving performance on the table.
When it comes to home projects, I never really know how much paint, stain, or primer to get. I usually end up buying a gallon, using what I need, and then just storing the rest. After a few years in storage, it becomes too old and ends up at the recycling center. This is how I came up with the idea of using sensors in SOLIDWORKS to calculate the amount of paint/stain I would need for any new home project.  For this blog, I’m going to use a section of railing, but I imagine this would also work great on an entire deck, a room in my house, the entire house itself, or even a part that I am manufacturing.
