Showing Articles written by Gary Ballentine
SOLIDWORKS users often need to customize their drawings to comply with company and industry standards, sometimes requiring different sheet formats for each drawing sheet. For example, a common practice is to include certain information on the first sheet only, which isn't needed on the others, such as the revision number or other custom properties. To do this, you need to create two sheet formats and specify which sheet format to use for the initial and subsequent sheets.
At times, SOLIDWORKS users will need to customize their drawings to meet company and industry standards. This generally starts with modifying an existing drawing template and sheet format, whether it’s the default templates and sheet formats included with SOLIDWORKS or an existing sheet format used by their company. This allows us to change everything that first appears in the drawing when you create a new one, along with several items you can’t see initially, such as settings or drafting standards.
While the SOLIDWORKS Tab and Slot feature is primarily intended to be used when creating multibody sheet metal parts, design requirements sometimes involve adding Tab and Slot features within an assembly. This is simple enough when a part is only used once, or the feature is added after all instances of the part are inserted, but sometimes a part needs to be reused.
In SOLIDWORKS, materials in multibody parts work similarly to materials in single body parts, except you can assign materials to individual bodies to override the main part material. When you apply a material to the whole part (at the top of the FeatureManager Design Tree, as you would with a single body part), each body automatically inherits the material. This is exactly how single body parts work. You can then specify different materials for specific bodies if desired. This allows you to create your model as simple or as detailed as you want.
SOLIDWORKS Visualize Jun 23, 2025
SOLIDWORKS Visualize supports high-resolution 4k displays. So, why isn’t your model showing in high resolution? Because of a simple Viewport setting—and it isn’t a setting in Windows. The Viewport is the preview of your project that you see when you’re working on it. By default, it’s set pretty small. This is to increase performance and load times, and it doesn’t affect your final export. It’s just there so you can see what you’re working on, and you can customize the size to your liking.
When a sketch in SOLIDWORKS is fully defined, it means that all the necessary dimensions and relations are in place. Fully defined sketch entities can't be modified when editing or creating other sketch entities. This makes the model more predictable and gives each sketch entity a controlled size and location. One quick way to do this is to use the Fully Define Sketch tool.
SOLIDWORKS Composer Mar 04, 2024
SOLIDWORKS Composer files (like SOLIDWORKS files) contain important model information that can be used to manufacture a model. This information can also be used to reverse-engineer a model, potentially compromising your intellectual property. In this article, learn how to protect files and your intellectual property from unscrupulous (or unknown) viewers.
SOLIDWORKS Composer Dec 11, 2023
SOLIDWORKS Composer imports SOLIDWORKS models so users can create graphical content and share projects with a wider audience. However, sometimes models import with missing actors or components - usually due to components loading in lightweight mode within SOLIDWORKS or import settings within Composer that exclude surface bodies.
