How to Troubleshoot SOLIDWORKS Crashes
Article by Nathen Blas on Aug 06, 2025
Everyone who has used SOLIDWORKS has at one time or another experienced a crash; whether that be a one time instance or a steady occurrence. In this guide, I will discuss some steps for how to troubleshoot SOLIDWORKS crashes, especially if this is a steady occurrence.
Note: This process will not work well with random occurrences as it requires some repeatability.
Why is SOLIDWORKS Crashing?
The first step to identifying what caused the crash is to determine where the issue is stemming from: such as the files you are using, the environment SOLIDWORKS is installed on, or the installation of SOLIDWORKS itself. This can be determined by asking some questions.
For files ask:
  • Does this happen with every file?
  • Where is this file located? Is it local, in PDM, or on a network?
For your system/install ask:
  • Does this same behavior occur on another computer?
  • When did this start? What happened on your computer around that time?
How you proceed is determined by how you answered those questions. For instance, if this only occurs with one file on any computer it is used on, it is likely a file issue and will need to be looked at closely by a GoEngineer Technical Support Engineer.
On the opposite side of the spectrum say the issue only happens on one computer with any file used, this would be a system/install issue. We will proceed with this case and look at how to troubleshoot this type of issue from here on out.
Information is the best tool
Now that we know have an idea of where the issue is stemming from we need to gather information. The best place to start is by getting information about your system. To do so, go to the Windows Start Menu and search “System information”.
How to Troubleshoot a SOLIDWORKS Crash
Figure 1. System Information.
Once we have the system information up and running we are going to look for some specific pieces of information.
The System Summary looks for:
  1. OS Name
  2. System Manufacturer
  3. System Model
  4. Processor
  5. Installed Physical Memory (RAM)
In Components > Display:
  1. Name
  2. Driver Version
Component Display Troubleshot SOLIDWORKS Crash
Figure 2. Component > Display.
With these pieces of information, we can see if anything glaring about the system is the issue. The OS is a big one to look for. If the OS name is Windows 7 Home or Windows 10 Home, this is very likely the cause and it is suggested to get either Windows 7 Pro/Enterprise, or Windows 10 Pro/Enterprise before proceeding.
If you get to the display page and you see more than one graphics card we will need to check to see if SOLIDWORKS is using the correct card. In many instances of dual cards, one is an Intel HD card. If SOLIDWORKS is using this card it is likely the issue as many Intel cards are not powerful enough to run the program.
Knowing this information, it is a good time to check to make sure your system is running the recommended hardware. You can compare your system to the minimum requirements here.
Talk to me, SOLIDWORKS
Now that we know more about our system, it is time to have SOLIDWORKS tell us a little about what is going on. To do this SOLIDWORKS has a powerful set of tools in the SOLIDWORKS Rx. To access this go to your Windows start menu and type in ‘SOLIDWORKS Rx XXXX’, with the XXXX being the year/version of SOLIDWORKS having the issue. Launch this program.
SOLIDWORK Rx Troubleshoot SOLIDWORKS Crash
Figure 3. SOLIDWORKS Rx XXXX.
Related Article: How to Make a SOLIDWORKS Rx Problem Capture
Inside of the SOLIDWORKS Rx, some tabs will give you different information about the program. Let's start by checking out the ‘Diagnostics’ tab. This tab tells you common system information and settings and gives warnings on basic issues. We are mainly focused on the system information portion where it will tell you any hardware SOLIDWORKS doesn’t agree with. Check this to make sure it matches what you found in the System information and if the Graphics Driver needs to be updated. You can check to see what driver your card should be running here.
Let's get back to the ‘Home’ tab and run a couple of tests. In the home tab, we want to run the safe modes at the bottom of the page.
Safe Modes Troubleshooting SOLIDWORKS Crash
Figure 4. Safemodes
To run the safe modes we will need SOLIDWORKS closed. At this point, save any files being worked on and shut down the program. The first safe mode we want to test with is the OpenGL mode. Click the blue text stating ‘Click here to launch SOLIDWORKS in Software OpenGL mode’.
What this safe mode is doing is bypassing the GPU(Graphics Card) and is going to run SOLIDWORKS off of the CPU. The reason for doing this is to test if the graphics card is the cause of the problem. Once that safe mode is up and running, go through the same process that causes the crash. If the crash does not occur, the issue lies with the graphics card. Take a look to make sure the card is certified and the driver is up to date. If they are not certified and up to date, getting them to that state will likely fix the issue. If it does not, more troubleshooting will be needed. If the issue occurs inside of this mode the fault lies somewhere else. Close down the program and let’s try the next safe mode.
The next safe mode is bypassing tools/options. Click the blue text stating ‘Click here to launch SOLIDWORKS while bypassing Tools/Options Settings’. This safe mode is going to run SOLIDWORKS on default settings which will tell us if the issue is with the System options or possibly the registry.
Once this safe mode is up let's perform the same process and see if the crash occurs. If it does not occur in this safe mode, resetting the registry will resolve this issue. If it still occurs we will need to continue troubleshooting.
If the issue was resolved by the Bypassing tools/options or not, our next step is going to be resetting the SOLIDWORKS registry. This is because the safe mode does not touch all of the registry keys that could be causing the issue.
Resetting the SOLIDWORKS Registry will make the program revert to a factory zero state. If you have a lot of custom settings, it is advisable to save these settings beforehand so you can restore them after the reset. To do so follow the steps inside of this article.
To reset the SOLIDWORKS registry:
  1. Go to the Windows Start Menu and search for ‘Regedit’
  2. Launch the Registry Editor
  3. Once that is open we are going to a very specific path:
     Computer\HKEY_CURRENT_USER\SOFTWARE\SolidWorks
  4. Inside of the ‘SOLIDWORKS’ folder there will be a folder labeled, ‘SOLIDWORKS XXXX’, with the XXXX referring to the version of SOLIDWORKS experiencing the issue. Such as 2018,2019, etc.
  5. Rename the ‘SOLIDWORKS XXXX’ folder by adding OLD to the end. It will look like this: ‘SOLIDWORKS XXXX OLD’
  6. Click off of the folder and close the Registry Editor
  7. Launch SOLIDWORKS
You will be asked some questions about resetting settings and toolbars. Select the appropriate answers for what you want to happen and agree to the license agreement. After SOLIDWORKS is up, we will want to test again to see if the crash still occurs. If it does not then the issue was fixed by the registry reset. At that point, if you created a settings file you can restore the settings via the copy settings wizard.
Event Viewer
If the crash is still present after those tests it's time to get some more information. The best place to get this information will be the Windows Event Viewer. To get to your event viewer to see the application logs:
  1. Go to your Windows start menu and type in ‘Event Viewer’
  2. Launch the program and expand ‘Windows Logs’
  3. Selected ‘Application’
Inside of Application logs, we want to look for an error for SOLIDWORKS to determine the faulty module. It should look something like this.
Event Viewer Troubleshoot SOLIDWORKS Crash
Figure 5. Event Viewer
Based on the Faulty Module you will be able to determine if it is a SOLIDWORKS issue or a Windows issue that your IT will need to address. The one shown above is a Windows Error. This can be determined by the path and where it points to.
SOLIDWORKS CXPA Files
Another useful diagnostic tool is the crash dump files generated by SOLIDWORKS. While more useful to a GoEngineer Support Technician, it’s worth familiarizing yourself with these files.
Navigate to the following file path:
C:\Users\<USERNAME>\AppData\Local\SOLIDWORKS\CXPA
When you arrive at the file path above, you will see many more .zip files than you do crashes. At this point, if you feel you are too far in and don’t feel comfortable, go ahead and grab the last 10 or so .zip folders written and send them to another compressed folder (.zip). When you contact Technical Support with a crashing concern, they will request these logs from you.
If you’re still with me, great! Find those CXPA logs with a larger size than those surrounding it – that will likely contain a crash (see image below).
SOLIDWORKS Troubleshooting CXPA Logs
Unzip one of the larger folders and look inside its contents. If it contains a ‘CXPD’ folder, this log was from a crash! You can verify this by opening the other file in this folder, ‘SolidWorksPerformance.log.’ If the program terminated with a crash, the last line will either be <T> or <AT>, and there will be a <RAWSTACK> line in the log file.
If your GoEngineer Tech Support Engineer is reliably apt at diagnosing SOLIDWORKS crashes (a specialty we all appreciate!), they might be able to determine a faulting module from the <RAWSTACK> line.
If this does not indicate other than some generic faulting modules,  there are additional tools at our disposal that can let us look a little further into the program, specifically WinDbg.
WinDbg, or Windows' debugger app, is a publicly available debugger tool which “can be used to analyze crash dumps, debug live user-mode and kernel-mode code, and examine CPU registers and memory.”
Once WinDbg is installed, you may access it by typing ‘windbg’ in your Windows Start Menu and launching the program.
Search for WindDbg Windows Debugger App in the Windows Start Menu
You will get a screen that looks something like this:
Windows WinDbg App for SOLIDWORKS Crashes
Return to your CXPA folder location, unzip (if you haven’t already) one of your crash logs, go into the CXPD folder, navigate through one more folder (it will have a date- and time-stamp as its name as well as your SOLIDWORKS version number), until you reach a destination containing a .dmp file.
You will drag and drop the .dmp file into your WinDbg window, and it will start running and indicate ‘BUSY’ while it loads.
Once this finishes, type !analyze -v in the command line and hit Enter. This will analyze your file and output information for Tech Support to analyze.
Keep in mind, this is a hit-or-miss process, as this will generally only catch those issues outside of the actual SOLIDWORKS program. If there is a SOLIDWORKS-specific .dll module causing the crash, this will generally not be indicated by this investigation. The source of the crash will have to, in this case, be found by an alternative troubleshooting process. If, however, the issue is more related to the prerequisites of the software, this will be indicated.
For example:
Situation: The faulting module is indicated to be ‘mfc140u.dll’ by WinDbg, by a group of lines similar to:
SYMBOL_NAME:  mfc140u!CWnd::EnableWindow+0
MODULE_NAME: mfc140u
IMAGE_NAME:  mfc140u.dll
FAILURE_BUCKET_ID:  NULL_CLASS_PTR_READ_c0000005_mfc140u.dll!CWnd::EnableWindow
Solution: This has been shown to be alleviated by a repair of or reinstallation of SOLIDWORKS, including the Microsoft Visual C++ redistributables
When in doubt, contact us at GoEngineer Technical Support for any concerns or questions.
Repairing the install
If the registry reset did not resolve the issue and the Event Viewer pointed to a SOLIDWORKS error, the environment is not the cause of the problem and it is most likely the installation of SOLIDWORKS.
The next step is going to be repairing SOLIDWORKS. If SOLIDWORKS was installed via admin image repairing is not an option and uninstalling and reinstalling the image will essentially complete the same task.
To repair SOLIDWORKS:
  1. Go to the Windows Start menu and type in ‘Control Panel’
  2. In the Control Panel select ‘Programs’ > ‘Programs and Features’
  3. Scroll down through the list of programs and find ‘SOLIDWORKS XXXX SP0X’
  4. Right-click the appropriate program and select ‘Change’
  5. This will launch the SOLIDWORKS Installation Manager
  6. Select ‘Repair your Installation’ and hit next
  7. The next menu will ask what you would like to repair. Leave everything checked and hit 'Repair'
Let SOLIDWORKS run through the repair and once complete, launch the program. Test the same process to see if the crash still happens. Should the crash still be present the next step is going to be uninstalling and reinstalling. For this process, we have a complete SOLIDWORKS clean uninstall guide.
Should the reinstall not resolve the issue it is best at this time to contact our GoEngineer Tech support. This will give them a great platform to start from and they will know of some tools to better identify the issue.
Editor's Note: This article was originally published in November 2020 and has been updated for accuracy and comprehensiveness.
Contributing Author: Camille Johnson, SOLIDWORKS Technical Support Engineer at GoEngineer.
SOLIDWORKS CAD Cheat Sheet
More Helpful SOLIDWORKS Articles
How to Deactivate SOLIDWORKS if You Cannot Launch It
Remote Access to Your SOLIDWORKS Network or Standalone License
Recovering a Hung SOLIDWORKS Network License
SOLIDWORKS License Manager Tutorial
How to Rebuild the SOLIDWORKS Registry
About Nathen Blas
View all posts by Nathen Blas
